Cross disolve
  • Cross disolve
    Hi,
    Does anybody know the name of the dip to black (from adobe premiere) effect in edius?
    I'm also searching for an effect that does the fade in/out for the audio signal
    thanks
    check out
    www.belga.be
    http://picture.belga.be
    http://video.belga.be/belgavideo
    Belga News Agency
    For audio you can:
    1 fade with rubber band.
    2 Use the fade buttons a top the timeline
    3 Apply an audio fade transition (from the audio transition folder)
    4 put your setting that an audio fade is applied when you add your default transition
    Fade to black:
    1 mixer rubber band
    2 apply a dissolve
    3 use the fade button a top the time line
    4 create a black color matte and dissolve to the clip.
      If you do not see the fade to black buttons on your timeline (Like SR suggested) then go into settings/application settings/customize/ buttons/timeline
      You can add then there :)
        mm the disolve effect does not do what I want...I want that the transitions goes to black totally and then shows the new fragments.
        The fade to black buttons are doing this but it seems that I cannot change the duration?
        check out
        www.belga.be
        Belga News Agency
          don't bother guys I made a very stupid mistake!
          check out
          www.belga.be
          Belga News Agency
