Unable to apply muliple crossfade to audio
  • Unable to apply muliple crossfade to audio
    It will work if I drop the dissolve on the video but if I apply a crossfade to audio it either only adds 1 crossfade or sometimes adds 3 or 4 say over 10 cuts.
    Someone mentioned turning off the sync mode but this makes no difference.
    Using version 4.54.
    Any help appreciated
    Cheers
    Phil
    Phil
    Intel Core 2 Duo 3GHZ CPU, Intel DP35DPM, 4GB DDR RAM, N/GEFORCE/9800GT, HD Spark, Edius 5.11, Viewsonic VX2260WM. Sony Z5, FX1.
    Hea Phil,
    Look to Settings|Application Settings|Insert default crossfade/transition tickboxes for the settings you may be after.
    Also, look at your crossfade/transition durations as well. This may be causing interference.
      Thanks Rusty,
      I've tried all that, only one I don't have ticked is the insert transition in crossfade which is what I don't want. If I tick this box then yes it applies the crossfade and the transition but I just want to crossfade the audio. Was this a bug in 4.54?
      Phil
      Phil
        It doesn't sound like a Bug.
        Do you have "Extend Clips" on and is there enough clip to extend?
          it does not work for me in Edius 4.61 so I assume that it is a bug
            If you could add this to the issues forum that would be great.
              Mike - similar issue.....
              Hi Mike,
              When I try to add an audio only transition (usually a simple Linear In/Out), EDIUS automatically adds BOTH audio & video transition. CANNOT add only an audio transistion. Used to be able to do it ! ! ! Any suggestion?
              Thanks and Cheers,
              Alan
              Alan J. Levi
              Director
              SYSTEM: ASUS P8Z77-VPro mobo, Intel 3770K CPU, 16 Gig Crucial 1866 RAM, Antec 1000W PS, EVGA nVidia 560Ti 1Gig Video, CoolerMaster CPU cooler, LG GGW-H20L BluRay DVD, SPARK card w/23" Samsung 1920x1080 Monitor, OCZ 240GB SSD boot in Swapable Tray & 3 WD Enterprise 1TB video RAID 5 HDD's. 4.5TB RAID 1 Outboard backups, Behringer2000 Audio Fader/Controller
                Alan, Make sure the audio and video are not linked together.
                  Thanks, Pat. I finally found that in my Settings/Application Settings/Timeline I had "insert default transition in crossfade" checked. Cured the ills - linked or not linked - works great now. Oh, the little things! Have a great weekend.
                  Cheers,
                  Alan
                  Alan J. Levi
                  Director
                    Originally posted by AJL14 View Post
                    Hi Mike,
                    Thanks and Cheers,
                    Alan
                    Alan... go into settings/application settings/timeline
                    Make sure the option add transition at crossfade is not checked :)
                      Cheers,
                      Alan
                      Alan, are you saying that you can now do multiple crossfades of the audio or just that you can now add a single crossfade without the dissolve?
                      Seems to me that my problem has crept in on my last upgrade as it was not there on previous versions.
                      Phil
                      Phil
                        Phil
                        it is a bug and is reported
                          I reported it 10 days ago but it is not showing up in the user reported section?
                            It appears that his bug has not been fixed in E5.
                            So frustrating having to apply audio only cross fade to each clip.
                            Phil
