Intel DP35DP and Edius DVX
  • Intel DP35DP and Edius DVX
    I'm trying to setup a DVX card in the DP35DP motherboard and I have the following problem
    I can capture through the DVX firewire but I cannot capture from the generic ports available through the motherboard.
    When I disable the DVX board everything works fine...
    I tried all the overlay modes but nothing changes...
    I have seen that the motherboard is on the list with the compatible hardware with the following comment
    When using IEEE 1394 board, need to add under [DVX-E1.dvxcore] in "Canopus.ini"
    Can anyone understand what I should do with it?
    Aristotelis Bafaloukos
    BEng (Hons), MSc, MBCS
    Ctrl+Alt+Delete
    Whoops
    I'm missing very important info that was on the next line. :)
    The full statement should read:
    Code:
    PCIConfigChange=2
      It is working now... thank you!
      How come nobody noticed that before? I guess that these boards are not very popular...
      Ctrl+Alt+Delete
        Not sure. But at least it's fixed for you (and the web page has also been corrected...in English at least).
          Dvx & DP35DP
          Originally posted by GrassValley_KH View Post
          Whoops
          Code:
          PCIConfigChange=2
          I have the inverse problem with the dp35dp + q6600 - 8800gt 512mbs, don't succeed in acquiring from dvx, but from integrated firewire him
