Problem with title effect
  • Problem with title effect
    Hi Folks,
    I created some svo's and subtitles.
    I can add them without any problem to my project. (targa format)
    I have just one issue.
    When I add the effect titlemixers slide a right I have a problem.
    The "in" effect works. The title is showed correctly.
    But when the out effects starts the title will disappear before the end of the effect.
    It seems that the effect is cut off.
    any idea?
    thanks in advance
    check out
    www.belga.be
    http://picture.belga.be
    http://video.belga.be/belgavideo
    Belga News Agency
    sorry, this is a bug
    to overcome, place the title on any video track
    go to 2D transitions and add Slide to in and out
    then go to in properties and load Slide from left
    then go to out properties and load Slide to right
      or you can use the Fade Slide titlemixer, it works correct
        So I can't use the Title tracks?
        Thank you very much for your prompt response. I will test it immediately!
        check out
        www.belga.be
        Belga News Agency
          you can use the Fade Slide titlemixer, it works correct on the title track
            I agree
            I agree with Anton use the Fade Slide titlemixer,
            cheers
              thx It works perfectly!
              check out
              www.belga.be
              Belga News Agency
