Will 4.6 work with old DV Storm Pro 2 card and Bay?
  • Will 4.6 work with old DV Storm Pro 2 card and Bay?
    Hi, I just wanted to know if this version of Edius supports the Canopus DV Storm Pro 2 card?
    Thank,
    David40
    Yes it does, Storm 2 and 4.61 are on my second workstation (check signature).
    In v5 of EDIUS Storm series will not be supported anymore, though.
      Yes 4.61 and if any fixes to the 4.6 release will be the last version in which the storm will be supported.
      Have a look at the roadmap
        Thanks for the info guys!
        StormDave, I noticed your primary system is running 9 Gigs of RAM. What OS are you using? I am told that you must run a 64 bit operating system in order to utiliize anything more than 3 Gigs of RAM.
