Edius v.4.61: my problems continue......
  • Edius v.4.61: my problems continue......
    Hi, today I have just done a project and with Edius v.4.61 besides having some previous problems, I have notices Edius v.4.61 doesn't work to my clicks on the buttons quickly. Edius works with a little delay. Edius never has given me problems but with this version I go mad. I have to installed it again but the problems all there are.
    What could I do, please?
    CPU: Intel i9 7940X
    SSD Drive:
    it is all instant here
    do you have some sort of auto protect enabled?
      I have any auto protect enabled. I am sure. With my PC I do editing video only.
      CPU: Intel i9 7940X
      SSD Drive:
        open taskmanager and see pf ram usage
        how much ram do you have and what is the min and max set for swap file (PC performance tab)
          I noticed the "Lag" in 4.60
            What graphics hardware do you guys have?
              ATI 1300 (something-or-other) on two machines.
              4.61 is actually snappier on my E6300 machine than my Q6700 box...
              go figure.
                This hardaware configutation never gives me problems, with Edius v.4.61 only:
                Mother Board: P5W DH DELUXE
                MICROP. CONROE E6600 2,40GHz FSB 1066 4MB cache LGA775
                RAM: 3 GB KINGSTON DDR800
                VIDEO CARD: SAPPHIRE RADEON X1950XT 256MB GDDR3
                HD: 1 SATA DA 160 GB-SISTEMA
                HD:2 SATA DA 160 GB RAID 0
                HD:2 SATA DA 250 GB RAID 0
                CPU: Intel i9 7940X
                SSD Drive:
                  I have RAM: 3 GB KINGSTON DDR800
                  I'm sorry, I have Italian verionsion and I don't understand what have I do precisely to see the RAM usage. Could you tell me in detailed way, please?
                  thanks
                  CPU: Intel i9 7940X
                  SSD Drive:
                    do you have Edius SP by any chance? if yes, that it acts as you say if external ref is set to external, basically it becomes useless
                    right click the taskbar, choose taskmanager and provide screenshot of this screen
                    fresh from my new PC :))
                    http://www.videoproductions.com.au/e...askmanager.gif
                      do you have Edius SP by any chance? if yes, that it acts as you say if external ref is set to external, basically it becomes useless[/url]
                      I'm sorry but I don't understand you. When did I tell you it?
                      right click the taskbar, choose taskmanager and provide screenshot of this screen fresh from my new PC :))
                      I attach you my screenshot with shut Edius. Then with open Edius.
                      In the meantime I opened Edius, in "USED CPU" I saw a 65% of maximum increase.
                      thanks for some info.
                      CPU: Intel i9 7940X
                      SSD Drive:
                        I have a different problem too. In fact with v.4.6o I used 5-6 titles at the same time. Now with v.4.61 I cannot use 5-6 titles at the same time. I have to do rendering. Many problems with v.4.61.
                        CPU: Intel i9 7940X
                        SSD Drive:
                          what is Edius RT buffer set to? try 128
                          also, something does not look right with your swap file setup
                          try increase min and max to recommended value and then reboot
                          http://www.videoproductions.com.au/e...ual-memory.gif
                            Yes, my Edius buffer settings is 128
                            In Virtual memory my settings was:
                            2046
                            4092
                            I have just tried to increase min and max to recommended value (4221)
                            but it was impossible. A windows have suggest me to put less than 4097 value so that I put 4096 and 4096 then I have rebot my PC.
                            Unfortunately the problems are the same.
                            CPU: Intel i9 7940X
                            SSD Drive:
                              hmmm? I have no further ideas at this stage other than maybe trying an earlier version of the graphics card driver
