I just got Boris FX9 installed, my trasitions 3D transitions are very jerky, are their certain settings in Boris that need to be altered. (My edius system has he NX card). Gary
Boris and Edius
it is a bug
the only way to overcome is to select the transition
then double click the ruler, this will mark in and out
then press Shift+Q (this will add rendered file above transition)
now change the field order of the rendered file inside clip propertiesAnton Strauss
Glad that works for you Anton, I have tried it to no avail, are you working in SD or HD, so far it has evaded all my attempts to get that to work other than in SD.
Perhaps I missed something, still looking and trying
Anton
Cap in hand with an apology, I did it the first time you posted this BUT had not been able to reproduce until I read your post again.
I had been changing the field order on the original clip not the rendered clip --Daahh
ahaaaa, maybe I was not clear in my original post, this can happen after a few Wolf Blass Grey Label Cab SavAnton Strauss
NO! too much Barossa Valey Shiraz here
sorry, don't know about grafittiAnton Strauss
