Negative FX and Viewfinder POV
  • Negative FX and Viewfinder POV
    Is there a way to reverse a video image using color correction. I want to reveser the image to negative like film.
    Also, does anyone know where I can get a graphic to use as a POV camcorder viewfinder effect. I want to put the red recording light over some home movie video.
    Thanks,
    Bob
    There's a preset in YUV Curve called Nega.
      Use the region filter, enable the elliptical option and choose 'Block Color' as the inside filter - pick a safe red colour and there you go!
        Put the Region in a keyframed Blend Effects to make it blink or pulse.
          Bravo!
          Ingenious. You guys nailed that one for me.
          Thanks!
          bob
