Can't Find "Nx HD" Presets to start project in Edius
  • Can't Find "Nx HD" Presets to start project in Edius
    I just Upgrated for dvd storm pro2 to Edius Nx.
    But when I start Edius Just "Nx SD" prests are available and no "Nx HD" presets. I didn't installed original Eduis DVD comes with pack and I just Installed Edius 4.6. Is this my problem or something else,,,
    Edius NX,Intel Core 2 Quad 6600,Asus P5E ,ATI HD 2600 XT, 2 GB DDr2 , 4 Hdd 500 GB Raid 0
    Which model nx do you have?
    Because if you have the old model without the expension board I think the HD presets are not available.
      My edius Nx in Edius Nx PCIe version. So I think it should be new version. Do you think that I still need to buy expantion HD board?
      My main board is new ( Asus P5 E ) and I Installed my board in PCIe x1. Do you think installing the board in PCIe x16 will solve the problem?
        The PCI-E version requires 2 slots. (and it does not need the expention kit)
        What did you actually install?
        steve
          To be clear, EDIUS NX Express is different to EDIUS NX (PCIe) - the latter does not include the second daughterboard for HD component output.
          So if your package only consisted of one PCIe board, then you won't see HD presets.
            thanks to GrassValley_KH and SRsupport
            You really saved me from a week in confiusuion. My package consists of just one board. So as I got I have to buy another board.
            I have just one another problem with Dvcapture software. It just shows black screen in either Nx composit or Nx Dv devices. Is the problem relates to my New brand mainboard Asus P5E(chipset Intel X38) or Graphic Card (ATI HD 2600 XT) Or may incorrect IRQ assignment or something else at all...
              DVCapture uses an older system to reproduce video overlay. If updating to the latest graphics driver (Catalyst), Intel Chipset Driver, and DirectX from Microsoft does not resolve the issue, it could be a simple incompatibility with the software (old) not knowing how to work with newer hardware.
              DV ingest should be fine in the main EDIUS application, however.
                Do you have the latest version of DVCapture?
                  Yes pjsssss , I use last ver 1.1
                  so what is the solution ?
                    Really simple don't choose the nx input.
                    choose the camera name or vtr name and it will work as before.
