I have a SONY DSR-11 deck and want to record from a 16x9 Edius SD timeline from Storm system - and insure that the DVCAM Master tape will keep the 16x9 format for later dubbing up to Digibeta or BetacamSP. Any issues I need to be aware of to get proper 16x9 recording on the DSR-11?
insuring 16x9 Edius output to dvcam
If you use a 16:9 48Khz 16bit DVStorm-RT project, it will be properly flagged on the DVCAM tape. No worries, Ive done it plenty of times :)
When they dub it back to Digibeta for example, it's upto the person that's doing the dubbing to make sure that it is 16:9. Make sure to label your tape when you give it to them.
ahhh
Thanks, I feel confident it'll go right!
TobeDocumentaries and Art Projects
Hudson Valley, NY
i7 8700K @ 3.70 Ghz/16 gb RAM
windows 10
284 gb SSD boot drive
2 TB work disc
2TB storage disc
EDIUS 9.52.6031
