HOW to Key out all color except 1
  • HOW to Key out all color except 1
    OK my header does not explain - I am trying to use a slow section of black and white BUT I want to keep the Flower Button Holes On the three chaps Bright yellow - Have been playing with the region filter and its imposible as its not square!:-(
    I am sure this has been done here befor........my searches have come up with nothing, Maybe there is a technical name for this?
    Anyway I seem to remember its has something to do with the Grey's??????
    Cath
    Any pointers would be great!
    Chrominance Filter?
      chorminance.
      choose color you want to keep (key color)
      Effect inside (nothing)
      Outside monotone.
      Color stays /rest of the frame is b+w
        Further instruction can be found halfway through Video 6.1 here: http://ediustraining.grassvalley.com/
          Show-off :)
            This is not impossible using region filter. Try a soccer shoe that flies off the players foot, spinning madly and arcing all the while. It works, been done, try it.
            You need to (maybe) employ soft edge and elipse to get close. It won't be perfect but done right, you can't tell that easily.
            peterC
            Edius 9 v3
              Thanks! great help! -
              PeterC
              Where are these cobtols in the region filter setup.......If they are in there I cant see em.........I spent best part of 3 hrs looking, maybe NOT seeing though.......?
              Cath
                Open the region filter settings and look to right of the preview screen, there are 3 options among which: Ellipse and Soft Edge.
                Look at the picture out of the manual => yellow arrow
                Edius X - Edius 9.52 Pro - Win 10 64 - AMD-Ryzen 9 3900X - 32 Gb DDR4 - ASUS-PRIME X570-PRO - Nvidia GeForce RTX 2070 SUPER - SSD M.2 1000 Gb system + 3 x 3 Tb storage - 2 x 23" Full HD Monitors - M-Audio Studiophile AV40
