exported video gets jagged top edge
  • exported video gets jagged top edge
    Hi all,
    I have so many questions about exporting for various purposed, but I'll start with this one, which I assume is a simple one and I just don't get something:
    My goal is to have a clean output for web/internet delivery, the final format being quicktime h.264 which I do in Quicktime Pro. Either I export from the timeline directly to QT file, or to an uncompressed AVI that goes into Procoder express and convert to QT, which then gets recompressed in QT pro to h.264
    At any rate, When I export from the edius timeline (PAL SD 720 x 576) to an AVI (uncompressed) or to Quicktime using procoder express I always end up with a jagged top edge that I just don't know how to get rid of/clean up. I assume this jagged edge wouldn't be seen on a television etc. (overscan), but how to get a clean output for web delivery?
    Any advice is much appreciated. I am somehow lost in export options ****...
    Scot
    you can use the layout tool in edius to crop a bit from top
    or you can use TmPro to draw a thin black rectangle at the top to hide the problem
    or you can use source crop in PCE or PC standalone
    or if you are a tmpeg user, use the mask tool, this will not distort the video and you maintain max quality
      Thanks for the quick response. So, the jagged edge is normal/expected?
      If I use source crop, does this mean the final export will be slightly stretched in order to maintain the 720 x 576 ratio?
      Again, thanks, and I'll look at tmpeg as you suggested.
        http://www.videoproductions.com.au/edius46/T4-mask.gif
        Sorry, coming back to his. By tmpeg, are you referring to tmpgenc 4.0 xpress?
        thanks again,
        Scot
          yes correct
          I also have a Pal tutorial
          PAL Mpeg2 elementary stream encoding (m2v +ac3) using TMPGEnc 4.0 Xpress from tmpgenc.pegasys-inc.com
            if you have Procoder3 you can do the same, be sure to untick Scale after crop
            Anton Strauss started his Video Production Company in 1985 and is an accredited professional video producer by the AIPP
