Using Edius with Adobe Encore
  • Using Edius with Adobe Encore
    Is there some reason Edius will not work with Encore? We have an HDV project in Edius that we export as SD 16:9 to m2v and wave files. We then import to Encore. In Encore there are green flashes when there are photog flashes. The screen goes green for a few frames or breaks up like there is a tear in the video.
    The same source files when brought into Premiere work fine in Encore. Are we doing something wrong? Is there a setting somewhere or file type that is wrong?
    We are at a loss and time is running out on the project before we have to take some other steps.
    I would have thought that Edius output to Encore would be a great way to update from using DVD Workshop for all these years.
    Help,
    JoeO.
    Joe Oliverio
    Oliverio Productions
    "When a snapshot in time just isn't enough"
    6455 Almaden Expressway #102
    San Jose, CA 95120
    408-268-4000
    www.oliverioproductions.com
    Encore now uses the Adobe "Premiere" engine for display, which for reasons no one can fathom do not play files made by Procoder correctly.
    The flashes are a playback error only, and do not appear in the final mastered DVD, I'm using CS3 as well as Encore 2, always with Procoder files, and never had a failure yet.
    I think there is an update patch from Adobe for Encore 2, which stops it from random crashing when using Canopus files.
    Check the Adobe forum on this, it is well documented.
    Paul
      Thanks Paul.
      We actually first experienced the flashes on the burned DVD and then we saw them in Encore CS3 preview. So I don't think it is just a display issue. We have made an AVI export from Edius which bypasses Procoder and it plays fine in Encore preview. We are going to let Encore encode the AVI. I will let you know what happens. I think I am up to date on Encore updates.
      Joe
      Paul
      Joe Oliverio
      San Jose, CA 95120
      408-268-4000
        Have a look in the Procoder forum there's a thread titled Encore though choice(Martin Gleeson).It's a very long thread - I posted the solution - you will find it at the end of the thread.
        _________________________________
        Triple boot:Win10Pro/I7-5930K/GTX780/SSD-RAID/HDD-RAID/10GbE Intel X550/BMD 4K Extreme 6G/32GB RAM
        Triple boot:Win10 Pro/I7-6950X/GTX1080/SSD-RAID/HDD-RAID/BMD 4K Extreme 12G/2 x 10GbE/64GB RAM
        both on: 10Gbps Media sharing Network, 10Gbps NAS
