Titler Pro 7.9 Update 230907 issues
    Originally posted by Jerry
    Do me a favor.
    Make a very detailed video of your process and I will submit that to NB.
    No promises with this. Others I have asked get the same results as I do.
    This is my detailed video on saving a design to library
    Edius X (10.34)
    Motherboard MSI Z370 PC PRO
    CPU Intel Core i7-8700K
    Graphic Card NVIDIA GeForce GTX 1060 6GB
    RAM 32 Go
    SSD 970 EVO 1TB
      Originally posted by JohnnyD
      So is NewBlue better than Vistitle?
      i don't know if TP Newblue is better than Vistitle but I prefer Newblue for ergonomics and quality of title motions.
      Edius X (10.34)
      RAM 32 Go
      SSD 970 EVO 1TB
        https://we.tl/t-0NMd5KYTdr
        I was hoping you could show that you had to restart TP7 to view the preset. I take it that
        opening the library at the start helped.
        Try selecting the style before saving it to the library (The first section).
        See if that makes a difference.
          I have all 4 titlers that work ih Edius. I never use Quick Titler. I only use Heroglyph 4.0 for handwriting,
          New Blue FX360 which has all of the filters and transitions.....TP 7.9 is included in that. Vistitle is my main
          go to titler. I can do a lot within Vistitle. It is more resource efficient than TP 7.9.
          It comes down to what you are used to using. I've been using Vistitle since it was first offered for use
          in Edius.
          I will say, with the release of TP 7.9 New Blue has made the inner workings and file handling of TP 7.9 much better and it also
          provides a better user experience within Edius than before.
            I closed et restarted TP7 at 1'15 in the video (without restart Edius of course). You'll see design doesn't appears in the library.
            I tried different ways to saving (right-clic or file-->saving design) but it's the same thing
            Edius X (10.34)
            RAM 32 Go
            SSD 970 EVO 1TB
            • #21
              I have reported this.
