(Sorry for the long post - I just want to be specific to get best answers.)
Hi! I am a longtime user of Canopus products, and I also heavily use the Premiere Pro featureset. I currently have a Canopus Edius NX board (plus bay and component card), with both Edius 4.6 and Premiere Pro 1.5 installed on a self-built system.
When I first built out the system, I tried to use the Premiere Pro plugins Canopus provided; my thought was that I might use Edius software for simpler projects while using Premiere Pro for the more graphic-intensive projects. Unfortunately, the Premiere Pro plugin set was EXTREMELY unstable; Premiere would crash repeatedly when using the plugin, and even when the application worked, it became almost unresponsive.
So, abandoning that idea, I decided to simply work in native Premiere editing modes, occasionally taking my work over to Edius to watch through the S-Video output on a crummy consumer display (lowest-common-denominator checking). However, I finally decided that this is simply too inefficient; and plus, since I use Premiere Pro almost exclusively for editing, I was hoping to find a hardware solution that might work better within Premiere.
I have done a lot of research over the past few days. Here is the flow thus far:
1. I have always disliked the Matrox product line (especially compared with Canopus quality), but the only card out there that really seems worth looking at would be the RT.X2.
2. I have read comparison studies, and it looks like most people are completely for Edius NX over Matrox RT.X2; some have been willing to abandon Premiere Pro altogether and learn Edius just to have the stability and quality codecs that Canopus offers.
3. I don't have a lot of money to spend on solutions, so I am needing to decide on just one piece of hardware. I am torn because I love the stability of Edius software for some things, but I really need Premiere for most of the work I do. So I start searching forums to see how others have netted out on this topic.
4. Someone on a forum mentioned ADVC mode (I have not used this before) for the Edius NX. HMM..... OK, so I flip the Edius NX from Edius mode to ADVC mode. I start Premiere Pro 1.5 using a generic OHCI native editing mode, and I turn on DV preview. WHAM!! I've got full-quality previews of the Premiere timeline coming out of the Edius NX hardware.
This completely solves my problem... almost.
OK, so here are my questions:
1. I plan to upgrade to Premiere Pro CS3. Does anyone here know if the DV previews continue to work with ADVC-mode Edius NX? (All the forums I read say "Edius NX quits working after Premiere 1.5", but they all refer specifically to the buggy, horrific plugins. Has anyone tried with the ADVC approach?)
2. If ADVC mode works in CS3, then am I a moron for thinking that this solves my problem? (i.e. Is there some terrible quality loss, or format limitations, etc. using ADVC mode?)
3. If yes to 1 and no to 2, are there any compelling reasons to not pursue this workflow?
