I want to know about TYAN mother Board S5396 (Intel 6321ESB chipset,Intel 5400 chipset) support or not with EDIUS NX Express series hardware card.
NX PCI-X card
Originally posted by dvkong View PostI want to know about TYAN mother Board S5396 (Intel 6321ESB chipset,Intel 5400 chipset) support or not with EDIUS NX Express series hardware card.
After looking at the motherboard, it has 2 pci-e slots. The 16x would be for your video card and the 8x for whatever.
If you had the NX that had the pci-e and pci cards I believe the board would work. The pci-x board definitely would work, if you can find one. That does not have the encoder on board, neither does the pci-e pci setup.
The newer chipsets are not as problematic as the older chipsets and normally will work with fewer issues, if any. But then, there are occasions...Jerry
can NX card use for PCI-X slot?
I am use TYAN motherboard S2676 since 2005, I want upgrade to S5396
My Hardware board is "Edius NX for HDV" (old verson , use 64bit/66MHz slot)
The installation manual said that for HD editing use a 64bit/66MHz bus,
64bit/66MHz PCI slot is longer than general 32bit/33MHz PCI slot.
(Remark:I just need one slot for Edius NX hardware board to edit, no need Expansion board)
So, I want to make sure "Edius NX board is work for PCI-X type.
I know that PCI-Express slot is use for display card.
TYAN S5396 motherboard has two PCI-X 133/100MHz slots,
can I use this slot for NX borad?
Thanks!
http://www.facebook.com/album.php?ai...5&id=591487547
see my NX board photoLast edited by dvkong; 04-13-2008, 02:45 AM.
