w system but buffer slow down
  • #31
    In multicam the buffer is always limitedfor accuracy in switching. This is by design.
    • #32
      ok Jerry. Thank you so much for your help. I will have a look in upcoming multicam job and I will come back if there is still an issue.
      11th Gen Intel(R) Core(TM) i7-11700 @ 2.50GHz 2.50 GHz
      32,0 GB RAM
      Windows 11 Pro
      Gigabyte GeForce RTX 3060 12GB GDDR6
      EDIUS X Workgroup
      • #33
        If it persists, I could do a Team Viewer session with you.
        • #34
          Thank you so much! I will let you know
          32,0 GB RAM
          Windows 11 Pro
          EDIUS X Workgroup
          • #35
            why are you in 1/2 res preview quality?
            also, make sure that frame blending is set as default and not optical flow otherwise you buffer will be at 8 max https://www.videoproductions.com.au/...mo-default.png​
            • #36
              Anton, I was at 1/2 res because that way I could see the drone footage real time and not slowing down due to buffer drop. that was in the beginning before changing the settings.
              Also I didn't know that optical flow would drop buffer. Thank you
              32,0 GB RAM
              Windows 11 Pro
              EDIUS X Workgroup
              • #37
                George, you said that there were no effects on the clips. Depending on the setting, Optical Flow will eat your buffer alive.
                • #38
                  It is very important to give accurate information when asking for help.
