w system but buffer slow down
  • w system but buffer slow down
    Hello everyone,
    After building a new pc I thought real time playback would be better.
    No matter what change I make at Playback Buffer or at buffered frame before playback, buffer still goes max at 8, and if I have 2 or 3 tracks with simple videos of flares...then edius is slowing down so much.
    Is there any other setting I have to check?
    Thank you
    11th Gen Intel(R) Core(TM) i7-11700 @ 2.50GHz 2.50 GHz
    32,0 GB RAM
    Windows 11 Pro
    Gigabyte GeForce RTX 3060 12GB GDDR6
    EDIUS X Workgroup
    Could you post a screen shot of your project settings, the clip settings, and your timeline. Also, under System Settings>Application>Playback, try setting your Playback Buffer size to 8GB.
    Your chip does not have any hardware encode or decode acceleration for AVC encoded clips. This may have some bearing on playback. If you are indeed using AVC encode clips (H.264, H.265) transcode a couple of clips in the bin to HQX to see if that improves playback.
      here is the project settings.
      I had playback buffer at 2GB and frames at 15
      32,0 GB RAM
      Windows 11 Pro
      EDIUS X Workgroup
        Ok. here is the situation. In a sequence with 2 cameras edited buffer goes to 500. In a sequence that I edit the teaser (final edit 3 minutes) buffer is at 8
        I cant understand how this works.
        32,0 GB RAM
        Windows 11 Pro
        EDIUS X Workgroup
          I changed buffer at 8Gb and frames at 15. Close and run Edius again. Thats when the buffer went to 500. But in the small sequence buffer still stays at 8
          32,0 GB RAM
          Windows 11 Pro
          EDIUS X Workgroup
            What makes up the small sequence? Are all of the Audio Mixer channels set to 'OFF?' Are any other panels open and running?
              Do you use any third-party effects in the project which stays at 8 frames buffer?
                The audio mixer is always on. I dont use any kind of effect in this stage. So all the clips are just as they came from cameras.
                By small sequence I mean that for example when I make a teaser of a wedding the final length on all the sequence is around 3 minutes. There the buffer is max 8.
                In the sequence that I edit the 2 cameras, I have 2 hours of footage and even before edit buffer is at 500 (with the changes that Jerry recommended)
                Anyway. I will try in a project with multicam to see if I have a problem.
                32,0 GB RAM
                Windows 11 Pro
                EDIUS X Workgroup
                  Did you check what Jerry asked? Are all the channels of the audio mixer set to off?
                    Here is what it should look like
                      Are you in Multicam mode? I tested in 1920x1080 50p Multicam mode with 4 layers and I get the same buffer frames that you get 8.
                      Do you have a lot of effects applied to the clips?
                        No. No effect, no filter. Nothing
                        32,0 GB RAM
                        Windows 11 Pro
                        EDIUS X Workgroup
                          Can you post a screen shot of the entire desktop. Include the Audio Mixer in that screen shot.
                            ok here it is
                            32,0 GB RAM
                            Windows 11 Pro
                            EDIUS X Workgroup
                              and here is Edius
                              32,0 GB RAM
                              Windows 11 Pro
                              EDIUS X Workgroup
