Trouble with edius hub on installation
  • Trouble with edius hub on installation
    Some troubles with running edius…
    after installation edius x (last version) not running;(
    which anti virus program do you use? have you excluded the 3 Grass Valley folders etc? https://forum.grassvalley.com/forum/...878#post565878
      No antivirus, Windows 10, All folders are excluded
        What are your system specs?
          asus z370-H, 8700k, 16Gb DDR4 3000, win10
          So it was not possible to deal with the suspended EH services
          Now I'm trying to install a completely clean system​
            A clean install would be my recommendation. Get all new drivers from Asus and Intel.
              Best recommendation. On clean system all works fine ) Thanks
