Burning problem Edius 9
  • Burning problem Edius 9
    Hello, I've a small (?) problem with my Edius 9 : I can’t burn the compilation I have made,
    In burning mode, I see 3 buttons who stay grey, the compilation is a mixt of clips in 25 and 50 frames mode, all in Upper Field.
    What should going wrong here,
    Best regards​ Tiacha
    You do not have permission to view this gallery.
    This gallery has 1 photos.
    you need to add the sequence to the disk burner
    and get rid of the diagonal clip lines by dragging the right edge of the clip left until it snaps
      Hello, thanks for your fast reply, but the problem remains the same, adding the sequence give no result, the diagonal grid lines vanished when I changed the frame rate to 25, best regards, Taicha
        you did not select the sequence, you need to tick the small darker gray box next to Sequence1 so it has a tick in it (or check mark in USA terms)
        I understand that the interface does not make it clear that it needs to be ticked because the tick box does not look like a traditional tick box
        traditional tick boxes have a border
          I'm sorry, stupid from me, forgotten to set the marker .... first time I had to set this manually! Perfect now, thanks a lot !
            if the box would have a border, you would not have made this mistake, so not your fault, it is the fault of the software
