I've used it well. Suddenly, EDIUS X Pro was not running, so I deleted it and installed EDIUS X Pro, but I couldn't install it. Is there a way to install it?
It could be that your anivirus is blocking the installation. Can you please disable it and try again?
and
Running EDIUS installer is blocked (ediusworld.com)​
Also after installation don't forget to add the exclusions:
Is the previous version fully uninstalled? appdata/local/Temp folder empty?
is your Win user account an admin account?
if there is an icon called GV render engine near your time on the Windows taskbar, right click and pause prior to installingAnton Strauss
