Job Monitor with Multiple Projects?
  • Job Monitor with Multiple Projects?
    Just wondering if the Edius X job monitor can hold scheduled encodes from multiple projects like the Adobe Media Encoder? It seems to be per project but did not know if there was a way to log and access it separately. Thanks.
    the one on the EDIUS taskbar shows only the current project
    the one on the Windows taskbar shows all projects from the last 7 days by default, unless you changed the 7 day setting
      Thanks Anton. So If I open a project, set two exports to the job monitor, can I open another project and set two more and have all four "in the cue"? Just wondering if it is designed to work that way. Sort of a global render cue.
        It should work that way
          "This is the way"
          Pawel Chyrowski
          Edius 9 Workgroup
            Great. Thanks. I will do some testing.
              Originally posted by Seemedia View Post
              "This is the way"
              Love it!!!
                Originally posted by GrassValley_PS View Post
                Love it!!!
                Cheers Pat ;)
                Pawel Chyrowski
                Edius 9 Workgroup
