Ahhh yes,thank you, forgot about that section. :)
Disappointing scrubbing of MP4's with new desktop build, also QuickSync Questions ...
MAIN SYSTEM: Asus P8Z68 DELUXE, Core i-7 2600k @ 4.6Mhz (stable), 32gb DDR3 1600 (1833 oc) Vengence RAM, 512gb SSD (OS and Apps Only), 256gb SSD Scratch Disk, 2TB Caviar Black SATA3 RAID Video Drive, Nvidia GTX 970 (oc'd), Windows 7 PRO 64-bit, all in a customized HAF-X case ... complete with holographic logo. [Air cooled into the low teens idle, 49c under heavy sustained oc'd load.] Dual 19" displays with 32" video monitor. ShuttlePRO.
What is the frame rate of the clip(s) you are testing? Could that be a part of the judder you are seeing? Unless they are 50/60p, you are probably seeing frame rate related judder with a horizontal pan from a fixed position.Asus Prime X299-A - Intel i9 7900x all cores @4.3GHz 2 cores @4.5GHz - 32GB RAM - NVidia GTX1070 - Edius 9 WG - BM Intensity 4k - Boris RED - Vitascene 2 - Windows 10
What type of cooling are you using?
Do you have any type of overclock on the system?
What is your PSU wattage and rating(Bronze, gold, etc)?
Do you see the same issues when scrubbing in a 1080 60p project?
Are you viewing the scrub process on a computer monitor or by way of a dedicated I/O card out to a UHD TV/ monitor?
Not sure if you saw this comment: https://forum.grassvalley.com/forum/...928#post575928 where the issue is only when using the mouse, not with other methods of scrubbing through the footage.
On an i9 12900k I found that Gaussian blur crashed Edius X and I had to turn off the E-Cores in the bios to stop that.
Also I found that New Blue Fx were much more stable when hyper threading was turned off and it made no difference to Edius playback performance on my multi-core Xeon PC.
Scrubbing XAVCI UHD 50p on my laptop is very good with the mouse it just won't handle UHD 50p HEVC except in proxy mode.
MikeSys4: Edius9/XWG ASUS Z10PE-D16WS MB 2xE5-2696 Xeon 72 cores. 16TB RAID0 64G RAM RTX3090Ti. Samsung 55" QLED 1500 NIT HDR 4K TV. Storm3G Elite/Decklink 4K 12G HDR. Yamaha RX-A870 A/V 7.1 audio. Sys1-3 Edius 8.5 WG + RX-E1+HDBX1000 MIP HP xw8600 2 x X5492 CPU 8 cores, 8G RAM, GTX1080TI. All sys Fibred to central media pool - 5TB RAID + QLogic Fibre Switch. Central SD Pro VCR rack. All sys YUV & audio to theatre with Sony STR DN1040 7.1 audio amp with 1000W sub 63" HD 3D Samsung TV
I have noticed that with the primary monitor set to the iGPU motherboard socket the REC window is not smooth playback on a camera pan on an i9-12900k but swapping the monitors over in Windows and cables physically so the left hand monitor with the task bar is connected to the PCIE NVidia Graphics card and set to primary monitor gives a smooth result in the REC window.
Originally posted by createmedia View PostI have noticed that with the primary monitor set to the iGPU motherboard socket the REC window is not smooth playback on a camera pan on an i9-12900k but swapping the monitors over in Windows and cables physically so the left hand monitor with the task bar is connected to the PCIE NVidia Graphics card and set to primary monitor gives a smooth result in the REC window.
My understanding was that termination of the igpu was not necessary on later generations of intel cpus. You may well be OK.Sys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro19; Davinci Resolve18_Studio, GH2(hacked), Pana HC-X2000E, GoPro5
Sys2 :Clevo i7 6700K 2.5Ghz,16Gb ram 2565Gb SSD + 1Tb, (W10 Pro), Software: E8v3 WG; Vegas Pro19,Davinci Resolve18_Studio
