Hi all, let me wish all of you a happy new year fist.
As the new year started with changing my workstation to a new HP device, i had to reinstall everything. Right now i run into an issue with Edius X. For mastering a Blu_ray elementary stream i use since years the setting from Anton. Maybe you know them: https://www.videoproductions.com.au/...ay-export.html
I used this settings on my Edius 9, so i exported them and wanted to import these settings on my new Edius X workstation. Suprising for me, i could import them, but i dont find the settings in the dropdown menues anywhere. So i imported a second time, Edius told me, that the settings already in, but i cant find them in the "drop down menue".
Maybe someone has a tipp for me, where i can find the settings? Thanks in advance already!
So i thought, no problem, i re-configure in Edius X, according to the template from Antons Homepage, but i even could find an MPEG elementary basic setting in Edius X. Did i miss something? If Antons setting are not working any longer, which settings are you using for a Blu-Ray elementary stream to create?
BR.
Werner
BR.
Werner
