Changing Project Settings
  • Changing Project Settings
    I have footage filmed in 4k resolution. Client only wanted HD delivery so I edited in a HD project.
    Can I now change the project settings to 4k and export the video in 4k without any loss of quality or would it best to start over with a 4k project from the start?
    Motion Art Cinematography
    Windows 10 Home 64 bit, Intel I7 4.2ghz, 32GB Ram, Nvidia GeForce GTX 1070
    Gold Coast, Australia
    you can switch to 4k and export and it will be perfect, no need to start again
    however, if you used any quicktitler titles, check and resize and re-position them once you switched from HD to UHD
    no such issue when using Vistitle
      Thank you Anton.
        If I'm using UHD files I always start a 3840x2160 project with Lanczos 3 Hi Quality settings.
        Then I change to HD for down conversion export.
        After that I return to 3840x2160.
