old project error
  • old project error
    Hi, I have change my edius worksation , i made a online deativation and reactivate in a new PC. now when I try to reopen the projects they give me a error and dont open
    where is the error , to try correct?
    regards
    What is the actual error message? What version of EDIUS?
      hi, my edisu version is 10.34 and I join the sistem report in attachment becouse the error dont have a number
        Hi there,
        If I look at your log and if I have read it correctly, it seems you are able to acces your project and can do some operations.
        Can you please be a bit more specific at what point you get issues?
        This project: t 2022-11-02 estudo sobre o clima.ezp seems to open.
        ​Is this the project you are trying to work on or another one?
        Can you try this for starters?
        Cut all the vst plugs from this folder C:\Program Files\Grass Valley\EDIUS X\PlugIn\VST\
        and paste them in a folder on your desktop.
        Start EDIUS and check if everything is normal.​
          at the start , I see the project in edius menus lastest projects, choose one, (one month or 2 older) and then open... it starts , and when he start to see the project it close
            Did you remove the vst plugs as I suggested?
              i dont did nothing and it open normaly...
                I am not undestanding your answer.
                Did your remove the vst plugs and open an old project?
                  I start the worksation after lunch and edius open the refered project normaly!
                    Ok glad that it is solved. :)
                      empty appdata/local/Temp daily
                      disable faststart in power options
                      with the above two items done, many problems may vanish
                        TKS , I will do it dayle
