multiple clips speed change.
  • multiple clips speed change.
    I need to change multiple clips speed on timeline. If I do this with one clip is allows all the later clips to slide right, But not with multiple clips !!
    Any Solution.. Plzzzzzzzzzz
    At this stage there is no way to have multiple clips stretch when pasting Clip Speed
    I am not sure if it has been requested
      Thanks for the reply sir, Now what i do is,,
      1, drag sequence 01 to the BIN.
      2 create a new sequence, seq2
      3 now drag "sequence 01" from BIN to timeline on "seq2"
      4 than it comes like a clip, only then i can change its speed
      but it is time consuming a lot. and i have to create a lot of sequences. plz grassvalley can u look into it.
        EDIUS allows you to paste the clip speed from one clip to many other selected ones in one hit, but they do not stretch on the timeline, you would need to manually stretch each clip
          You can do as Anton suggested, but change it to Stretch to Fit (not the default of Keep Original)). It should work, though I have not tried it yet.
            the stretch to fit is only for layouter keyframes and dissolves
            it does not work with speed change, maybe it needs to be requested if it has not been requested already
