Edius X error code: 8000ffff
    for the moment, you could assemble the show without using sequences, there is a button you can add to timeline that copies everything between in and out and then paste to new sequence, see attached
    can I see the project settings and clip properties, maybe there is some mismatch that could cause sequence waveform generation failure?
      I finally had a chance to test this myself and it is broken in 10.33
      some sequences work, others don't, and they don't even register in job mon
        It works correct if project is started in 10.33
        in my case, most recent projects were started in 10.32 and they all fail in 10.33
          Thank you.
          What are the 10.32 and 10.33 values? Are they the time?
          Then the issue is an Edius bug or depending on any of my configurations?
            That surprises me a little bit because:
            Most of my projects were started earlier than 10.32 and taken over whith each new version - no problems when working with 10.33.
            kurt
            NLE: EDIUS-X(10.34.10198)-WG; RESOLVE-18.1.4.0009 Studio
            // Read > Test > Understand
            • #21
              Hi, I don't know what could have happened but now I haven't any error messages, and the audio waves of the sequences in the timeline are rendered correctly without any problems... ??
