Edius X 10.32.8750 - GV Job Monitor not run tasks
  • Edius X 10.32.8750 - GV Job Monitor not run tasks
    Hi all! Not work all tasks - print to file, convert file, proxy creation, waveform creation. All tasks freezed with «Loading» status ;(
    At some point, all this stopped working, but I didn't understand at what point, everything worked well earlier.
    What could have happened?​ Thanks for help)
    P.S. In Edius 9 all works good on the same PC
    Check the exclusions in your firewall
    Hi all, The moderators of the forum will be sharing tips in this thread . If you have any suggestions feel free to send me or Grassvalley_PS a PM.
      https://forum.grassvalley.com/forum/...878#post565878
      C:\Program Files\Grass Valley\EDIUS Hub\EH Render Service\EHRenderService.exe
      C:\Program Files\Grass Valley\EDIUS Hub\EH Render Service\EHRenderServiceHost.exe
      C:\Program Files\Grass Valley\EDIUS X\EHRenderWorker.exe
      C:\Program Files\Grass Valley\EDIUS X\XREAdminConsole.exe
        go to EDIUS help menu and generate a system report and attach here, I will then tell you the cause of the failure
            I checked your report and the reason for export failure is an incompatible plugin.
            Delete the following plugin: Titler20Plugin7.tpi in NewBlueFX/Titler/ folder of EDIUS X Plugins folder
            Titler20Plugin7.tpi only works with EDIUS 9 and earlier, so since you also have EDIUS 9 and 8, don't uninstall this titler, only delete the tpi
            Restart PC and your export will work
            if you need the newblue titler, you must install the one that comes with EDIUS X, go to EDIUS help menu and click Bonus Software, then download Newblue for EDIUS X, then install and you will have Titler Pro 7
              Thank you very much! Everything works as it should)
