Color Opinion
  • Color Opinion
    With NewBlue or built in Edius 7.0 color effects, how would you improve the color composition of this video. Expert opinions humbly requested.
    can you supply a full resolution still of the timeline
      Is this okay?
        no, I need a still image of the timeline, click the "save image as" button on timeline toolbar and choose jpg or psd
          That image above is from the button you see I pasted here. I clicked the Create A Still Image button. That is right from the timeline, right?
            it appears you have layouter applied to both images in the shot
            can you disable the layouter to get a still of the original size
            there are two still image buttons, use the save image as and choose psd or jpg
            if you don't have the button, add it in user settings
              this is from a zoom meeting... the whole shot is inside a zoom meeting... I have not applied layouter... I don't have two separate video clips from the zoom meeting with each active speaker
              am I explaining this properly?
                in that case, I would duplicate the V part of the clip and place above
                then crop each clip so all outside is not altered by PCC
                then apply PCC to each clip and adjust for best results
                you will not be able to recover overexposed items like forehead
                  I would say the skin tones look a little over saturated and a bit yellow. So maybe lower the saturation either globally or pick just the skin tones with 3-way CC. Then add some blue to lower the yellow or move the color wheel a bit. You can use the 3-way CC for this as well with the middle section having the most impact. Highlight section in 2nd place.
                    you can use the skin tone line on the vector scope to help you adjust skin tones.
