Edius 8.5 WG not recognising blank DVD for burning
  • Edius 8.5 WG not recognising blank DVD for burning
    It is some time since I have burned a DVD from Edius. I am using Edius 8.53 WG and Windows 10 Pro and Edius does not recognise a blank DVD. I have two burners in the PC and both have the same issue. I have tried different previous projects in Edius as well as different blank DVDs.
    Any suggestions I should try? I have recently reverted back to using Microsoft Defender instead of Kaspersky. Could that be a cause?
    I appreciate I could use another program to burn a DVD, but I would like to get the one in Edius to work again.
    Since Anton recommended using third party software (Nero, Image Burn, etc.) years ago, that is all I use, after burning the timeline to file. He was right. Windows and Edius are unreliable for burning trouble-free discs. It's really counterproductive to try.
    Regards,
    Jon
      I have managed to solve the issue. It was Defender blocking the burn to disc. I knew about excluding folders when installing Edius, but I didn't realise that it was necessary after it was installed. In my case I just excluded the Grass Valley folder in Defender and now can use Edius to burn the DVD.
        you need to exclude all 3 Grass Valley folders
        https://www.videoproductions.com.au/...exclusions.png
