Timeline cursor behavior when delete between in out in ripple delete mode
  • Timeline cursor behavior when delete between in out in ripple delete mode
    Could the timeline cursor move to the start of the clip when delete between in out in ripple delete mode? Now the timeline cursor stay in the same timecode, not move to the start of the clip. Could I change this settings somewhere?
    Miro Remo
    www.miroremo.com
    1.DESKTOP: GIGABYTE x79 UD4, Intel Core i7 i3930k, 32 GB RAM, NVIDIA GTX 760, 14x internal HDD + mirrored backup, HD SPARK, Sound Blaster Audigy, LG DVD-RW, WINDOWS 10 x64
    2.LAPTOP: Intel Core i7 4702MQ, 16 GB RAM, NVIDIA GeForce GT 740 2 GB, Intel HD 4600, WINDOWS 10 x64
    yes, you can change that in user settings, application, timeline
      Hello Anton,
      and where? I don't see the option for this function.
      thanks.
      Miro Remo
      www.miroremo.com
        sorry, I misunderstood
        I would normally make a cut instead of setting in point, then I move playhead to where I want out point and press Alt+N, see attached
          Thanks a lot Anton! I am happy :)
          Miro Remo
          www.miroremo.com
