Edius X (10.32.8750) has problems with Batchconvert of Gopro HEV265 files
  • Edius X (10.32.8750) has problems with Batchconvert of Gopro HEV265 files
    Hi guys,
    I'm facing now a strange issue with Edius 10.32.8750 and Gopro clips filmed in H265 (1080p). As Mercali is much quicker in stabilizing H264 files, we always batchconvert the H265 clips from the Gopro in Edius before we start cutting the videos. Right now, we identified, that some clip, out of for instance 300 clips, are not in full lenght converted. We realized this as we have seen, the GoPro Operator is filming like hell on the B-Cam, but we didn't find the full clip(lenght) in the batchconverted version of the clips. So we re-imported the original H265 clips into Edius, and there the full lenght of the clips is available. So it look like during the batch-process, that Edius is only "partly" converting the clip. We didn't get any warning or hint on this issue. We see that "all" clips are converted, but some of them have only "half" of the original clip lenght.
    As i said, we are doing this in Edius, via the BIN windows, selecting all clips, right mouse click, batch convert, settings for H264 and then go. No error in render-manager is shown, no aborted clips or something else. When i look into the BiN window and Render manager everything looks fine.
    Any tipps how to solve this issue, or can someone confirm similar problems?
    Ciao
    Werner
    Werner Weißböck
    [SIZE="2"]X-trem production, Austria
    what happens if you convert one such file that failed? does it fully encode or only half?
    also, I would batch convert to something more realtime than H264
      Yes, I convert to HQX(fine) // Getting intraframe (performance against diskspace).
      kurt
      SW: WIN-10/64 PRO (22H2-19044.2130), Firefox u.a.
      NLE: EDIUS-X(10.33.9547)-WG; RESOLVE-18.1.0.0016 Studio
      // Read > Test > Understand
        How are you importing the files? Directly in the bin or via the source browser?
          Hi guys,
          here some further information. I checked the batch encoded files which had the length error and it must happen already during the batch process that only parts of the clips get converted. Playback a "corrupt clip" via VLC or some other media player, give the same result as the imported clip in Edius. So the batch converted file is not in the full lenght exported by Edius. Import of the files work fine and doesnt influence. If the converted source isn't longer you cant import a longer clip :-)
          Also, there is no clear structure, when a batch process failed in terms of clip lenght. some are longer and some not of the corrupt ones.
          Next what i tried, is to convert again a corrupt clip, not via batch convert and this worked. So i used the original H265 Clips, did a single conver with the same setting and everything was fine.
          Werner Weißböck
            Originally posted by X-trem production View Post
            Hi guys,
            can you disable GPU decoding (hardware) in system settings, importer exporter, AVCHD and then try the batch convert
              Hi Anton, will give them a try during my next project. Once it's done I'll let you know.
              Ciao
              Werner
              Werner Weißböck
