problems related to import analyze, and missing clip
    I analyzed your system report and can see the reason for render and export failure.
    Please remove the following tpi plugin from the plugins folder: NewBlueFX/Titler/Titler20Plugin7.tpi
    this titler plugin can only be used up to EDIUS 9, you must have copied it from 9 to X
    if you need an NB titler, download the correct one for EDIUS X (EDIUS help menu, download bonus content)
    Note: The built in Win Defender is very good and you never need to pay for it, there is no need to use Bitdefender
    YES!!! All working now as before, thank you for quick help. I havent figured that out without you! Crazy, i dont remember copiyng anything, as Edius X worked before, but now its alive again!
    Good work!
      It could be that Titler20Plugin7.tpi worked with older versions of EDIUS X but it totally prevents render service in 10.32 even if no title is used on the timeline
        Yes, might be, but thank you for helping me out....
