problems related to import analyze, and missing clip
  • problems related to import analyze, and missing clip
    Hi,
    1. video and audio files are no more analyzed in root folder.
    i manged editing the files somehow, if i used on some clips speed change (to 150% to whole clip), edius just hangs. Then i had second problem:
    2. i cant render with Shift+Q as normally. Nothings happens.
    if i deleted that clip and tried export with F11 to any format, i had 3-rd problem:
    3. Edius Claims that one track is missing, but its not. Edius forces me to restore the missing file, but its impossible.
    Deleted that clip from project and tried to export but it still says that clip is missing and no go.
    Uninstalled Edius Workgroup X 10.32 (latest) and installed again. Nothing changes.
    i used Edius for many years, but this is first time something like this happens...
    Any ideas?
    Originally posted by Aivar00 View Post
    Hi,
    Any ideas?
    Update.
    It came out Edius wont even play now regular file what is in timeline, also what is encoded in any previous project. Audio file playback is 2x slower, its not just slows, it is rattling.
    From Player everything plays fine, but when in Timeline then no. 1/8 quality it plays, but then picture is not good.
    Everything else works fine in computer - games, video convert with other programs.
    How to fix it?
      Update.
      How to fix it?
      Update 2
      Installed Edius 9 Workgroup for testing and everything in Edius 9 Works fine...
      Just Edius X Workgroup dont do anything, re/installing didnt help.
        your screenshots are showing that waveform generation is happening or pending, once that is done it should work fine
        until that is done, you won't be able to export
        what do you see in the job monitor, do you have a screenshot of it?
          In audio and video files are not being analyzed at all. I could wait for hours, it took before only seconds, now eternal stop.
            can you go to help menu and generate a system report, then attach here
            also, provide a screenshot of Job Monitor
            https://www.videoproductions.com.au/...ob-monitor.png
              First what kind of disk are you using for video. The harddrive is 92% full. Depending on the drive this can slow down certain processes.
              Are your projects stored on the same harddrive?
                4TB internal drive, clips are up to 189MB only. Same HDD.
                i understand "slow down", but its stopped.
                EVERYTHING works fine with Edius 9 Workgroup, just tested.
                  Jon Monitor is 0% always. No change.
                  System Report made by EdiusX System repport is too big for upload...
                  Edius 9 WG works fine, but not Edius X WG
                    This is strange. Check the first picture you posted. EDIUS clearly indicates that your disk D it is using is 92% used . Maybe you should first sort this
                      Did you set the exclusions in your firewall?
                        send the report via https://antonsvideo.wetransfer.com and I check tomorrow and let you know the cause of your issue
                          92% is true, there are other stuff also in that drive:)
                          at the time i installed and trie to use Edius, firwall was off anyway, i runned Malwarebytes Security witch does not include firewall at all.
                          But Edius X worked before fine, just one day it didnt. May related to latest update.
                            done!
                            Thanks!
                              I analyzed your system report and can see the reason for render and export failure.
                              Please remove the following tpi plugin from the plugins folder: NewBlueFX/Titler/Titler20Plugin7.tpi
                              this titler plugin can only be used up to EDIUS 9, you must have copied it from 9 to X
                              if you need an NB titler, download the correct one for EDIUS X (EDIUS help menu, download bonus content)
                              Note: The built in Win Defender is very good and you never need to pay for it, there is no need to use Bitdefender
