Default transition question
  • Default transition question
    Hey there. Was wondering if there's a way to drop a lower third title graphic onto the timeline (top layer) and have it fade-in and fade-out automatically without having to go to the FX bin to grab the 2D dissolve? If not, is there a faster way to accomplish adding the fade-in/outs than going to the FX bin? It's not a transition between clips that I'm using the dissolve on.
    Thanks!
    Mobile setup: Edius X - Laptop running i7-10875H CPU @ 2.30GHz 2.30 GHz (8 cores/16 threads) with 64GB RAM and NVIDIA GeForce RTX 2080 Super with Max-Q Design w/8GB VRAM.
    Desktop: Edius X - AMD 5950x installed in Asus ProArt Creator B550. 64GB Ram, 2 x 1TB m.2, 6TB HHD. EVGA 3080ti w/12GB vram. Running Windows 10 Pro
    You can add the fade in and fade out buttons to your timeline tool bar and/or map those fades to keyboard shortcuts. The fades will apply from the play head to the end of the clip.
    ifor example, to make a one second fade in, snap to the start of the clip, hit +100 in the number pad and then pres enter to advance 1 second and 0 frames, then press the fade in button or the keyboard shortcut that you map. (I have mine mapped for ctrl D for a fade in, and alt D for a fade out.)
    Edius WG 9.55.7761, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
      Thanks!
      Click the keyer track of the title clip and drag the dissolve to the info panel, your title will now have fade in and out in one hit
      https://www.videoproductions.com.au/...eyer-fades.mp4
