Hi Anton,
I have the latest Edius X 10.32.8648 Workgorup with BMC Intensity Pro 4K. Not that "save as", but the one where you set path where the file will be created. I tried to import that sequence into fresh project, but did not work.
I attached the picture of dialog box that did not show up in that specific project. That one is from another project that works.
Are you saying that the shortcut of F11 did not work? If you click the Export button (under the Recorder Monitor on the far right side), doors the Export box show up?
The shortcut F11 is working... My procedure is: I set on timeline In/Out point, then hit F11, set my H264 codec, click Export, and nothing happens. The dialog box where I set location and where the files has to be created is not showing up. This happend to a project I crated 6 months ago. Back then export was fine, today is not. On project I work recently no problem on export.
