Ik moet opnieuw installeren...HELP!!
  • Ik moet opnieuw installeren...HELP!!
    Hi all, I had to reinstall my PC.
    Unfortunately I can no longer activate Edius X. I don't have a serial number.
    I obtained this through EDIUS 9 "Plus" promotion at the time. Who can help me. What should I do?
    Greetings Geert
    Last edited by GraadCias; 07-29-2022, 07:09 PM. Reason: I need to reinstall...HELP!!
    Intel Core i7-6700K - Boxed, Windows 10 home 64 bit, Gigabyte GeForce GTX 960 - WindForce 2X OC - 4GB GDDR5, Kingston Technology HyperX Fury - DDR4 2666Mhz CL15 Kit 16GB, Samsung 850 EVO - M.2 - 500GB, Seagate 3TB SATA HDD, Gigabyte GA-Z170M-D3H - Socket 1151 - DDR4, 2x DELLP2415Q 4K monitors, 1x DELL SE2216H HD monitor, EDIUS 8, 9 and X
    login to the eID page and you will see your serial
    https://ediusid1.grassvalley.com/
    your reseller will also have a copy of your serial
    • GraadCias
      GraadCias commented
      Editing a comment
      Thank you Anton. You made my day!!
    Hi Anton,
    I have installed the latest update of EdiusX. Everything works. Unfortunately I miss New Blue Titler. Can you tell me how I can get it back?
      Originally posted by GraadCias View Post
      Hi Anton,
      EDIUS help menu, all the bonus plugins can be downloaded from there and also DVD menu templates if you use them
        You can download bonus content by going to the help menu and following the link.
