Batch convert from bin to Canopus HQX (to edit)
  • Batch convert from bin to Canopus HQX (to edit)
    Hello EdiUsers,
    I meet a variable problem to batch convert from bin to Canopus HQX (to edit)
    Genuine files are 80 all UHD coming from 3 sources all in MP4 (Camera Panasonic and 2 dji drones)
    - 1) operation, it takes without problem the first 40 files (mixed from all camera's) and export perfectly.
    - 2) operation, it accepts only the 7 following files in batch ...
    - 3) It accepts only 1 ...
    - 4) It accepts only 2
    - 5) It accepts all the rest (30)
    Is there something I have missed ?
    Thanks in advance
    Main System: Azus Z87 Pro, [email protected], 16gb ram, Nvidia GeForce GT 630, Windows 7 Pro 64, Samsung 840 pro, Edius 8.53.2808 WG and 9.54.6706 + NXexpress or HDspark, 2T separate video SSD.
    Now that I am editing I see some properties that could be the reasons of the problem.
    Some files received from drone Nr 2 where not in 50P but in 29.93 P or 25 P
    Camera is 50P - H264 and drone Nr 1 in 50P - H265.
    May be that can explain why the batch was "in parts"
    The HQX from drone Nr 2 stays as genuine 29.93 P or 25 P and is not smooth on the Timeline
    Any comments is welcome
      as far as I know, only the latest version of EDIUS X can batch convert clips of mixed frame rates
        Do the clips have different colour spaces?
          Thanks for these info... it confimes limitation of Edius 8 & 9.
            I didn't have look, I will... interesting question ! ... but as Anton mentiones, Frame rates seems already the cornerstone....
              Fair enough - I misread that as thinking it should do it and it isnt't where as Anton's comment already explains why it is not working for you.
                It was never an issue for me
                1. change bin view to Icon view
                2. sort by frame rate
                3. select all clips with the same frame rate and batch convert
                4. then select the other frame rate clips and do the same
                  Thanks David to have follow and big thanks Anton... this is the key as usual with you... reliable member !
                  This method is the one to follow.
                  I hope that thinks are more quiet in your region concerning the weather
                  Have a nice week
                    • I have never done otherwise (after the first time ;-) )
                    NLE: EDIUS-X(10.34.9923)-WG; RESOLVE-18.1.2.0006 Studio
                    // Read > Test > Understand
                      Thanks Kpot to answer and process. Exactly the same then Anton
                        Yessss this is the key....I have new files coming in yesterday. So, first open the the FPS in the bin, then select by type, and the batch is open.
                        Thanks to you all
                          Thanks to you all
                          Great that it works - kurt
