I have tried reinstalling my Edius 9 version after having issues with Edius X and after I install I get a crash report beofre the software opens up. I will send the report to support staff.
Edius 9 Crash before opens
Hello
I get an Edius X crash report with a lot of plugins on start up not always, but quite often. I just click exit and it carries on and loads up OK.
There seems to be a timeout on start and the crash report can come up in which it says Edius was taking too long to load.
You might need to uninstall again, delete your c:\users\username\appdata\roaming\Grass Valley folder.
The plugins folder often stays after an uninstall in c:\program files\grass valley\Edius 9\plugins. You may want to keep that and move that somewhere else and then delete the whole folder. You can injtroduce that back later and see if that is causing the issue.
The other thing you could have is a Steinberg or VST filter Edius doesn't like.
Regards
Sys4: Edius9/XWG ASUS Z10PE-D16WS MB 2xE5-2696 Xeon 72 cores. 16TB RAID0 64G RAM RTX3090Ti. Samsung 55" QLED 1500 NIT HDR 4K TV. Storm3G Elite/Decklink 4K 12G HDR. Yamaha RX-A870 A/V 7.1 audio. Sys1-3 Edius 8.5 WG + RX-E1+HDBX1000 MIP HP xw8600 2 x X5492 CPU 8 cores, 8G RAM, GTX1080TI. All sys Fibred to central media pool - 5TB RAID + QLogic Fibre Switch. Central SD Pro VCR rack. All sys YUV & audio to theatre with Sony STR DN1040 7.1 audio amp with 1000W sub 63" HD 3D Samsung TV -
Just because you get a "crash" report doesn't mean it is a crash. This box opens automatically if it takes EDIUS longer than normal to open. This is what yours is doing. As Mike mentioned, this is normally because of third party filters...either having a lot of them, or specific ones that cause problems.1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
2: i7 6950X OC to 4.5GHz, ASUS RAMPAGE V EDITION 10, Corsair Dominator Platinum 64G DDR4 2800, SAMSUNG 950 PRO M.2 512G, GeForce GTX 1080ti SC Black, Corsair AX1200i, Phanteks Luxe, 16T RAID HGST Deskstar NAS 4T, Corsair H115i AIO, BM IP 4KComment
