I created a title in QT... If I put it on video track it is fine, the same size as I created it ...If I put it on TTrack, its big, exceeds the whole frame. There does not appear to be anything applied to either instance to cause this, am I missing something?
Title question
answering myself resaving as... seemed to hhave fixed it
one othe silly question ...might find it I looked..How do I insert something in the beginning of a time line and have all tracks move back....and can I lasso all the tracks and clips and move things together?Jdroadie
Philly, PA
Edius 7.53 HDSpark, I7920, GTX470 Win7 64
if sync mode is off, only clips on the same track as the clip that is being moved will move
if sync mode is on, all clips on all tracks to the right of the one being moved will move, this is often very handy, so I keep sync mode on
shift+alt need to be held while dragging a clipAnton Strauss
