Hi, I use Edius 4.5 and I'd like to update it to Edius v.4.6. I'd like also to update Xpolde Pro 4.5 to Xplode Pro 4.60. Could you tell me if this update is free and it will work fine with Edius 4.6?
thanks, Ulisse
CPU: Intel i9 7940X
SSD Drive:
It works fine, a 2 bugs were fixed since the older Xplode Pro went up for EDIUS 4.x
I don't notice any difference between Xplode 4.5 and 4.6. Could you tell me where are these differences?, please
CPU: Intel i9 7940X
SSD Drive:
When Xplode Pro came out for free for EDIUS 4 users, it had a bug by crashing when you used a custom overscan setting with the Alpha transitions.
Then Xplode 4.50 came out and it fixed that bug but also made a new one where you were not able to select the renderer in the Xplode Config.
4.60 fixed both of these problems :)
Thanks for your info. But Xplode 4.6 haven't more transitions than Xplode 4.5?
CPU: Intel i9 7940X
SSD Drive:
Steve EDIUS Trainer, Grass Cutter Gold
