Job monitor refusal to export Edius X
  • Job monitor refusal to export Edius X
    Edius X Workgroup system 4 Windows 10
    All was going fine with an HD 50p project until I wanted to replace the file previously exported with a slightly better version.
    It had started exporting OK so I moved the in and out points to export a second clip and after that I was in endless red failed to export.
    If the old file is deleted from the hard drive before an Edius re-start it will export again but once it has stopped no other exports will work, even to a new file.
    I saw a window come up saying werfault.exe then under it said "The application" and no more words.
    I also saw the job monitor go white with a message "This page is having a problem refresh" I did refresh and job monitor returned.
    Go back to Edius 9WG. BEWARE! The VST plugins have returned to their default values in Edius 9
    The Edius X NVidia exporter produced a glitch in the sound which sounded similar to buffer run out on Edius playback.
    Edius 9 is perfectly happy overwriting the exported H264 file and the software exporter did not produce a glitch in the audio file.
    Event log error for Edius Hub
    GV.EDIUS.Hub.HTTPRequest:
    [::1] PUT /edius-hub/asset/v1/projects/7c356c562f314d92b6e66cdd64fd9e95 409 69ms
    User-Agent: EDIUS SAL
    Context-Type: application/json
    Context-Length: 82966
    GV.EDIUS.Hub.EHubException: Failed to save '6eb353d2c05640c9b169730dd56969d4' to DB.
    at GV.EDIUS.Hub.CBL.CBLDatabase.<>c__DisplayClass39_0 .<InBatch>b__0()
    at Couchbase.Lite.Database.<>c__DisplayClass79_0.<InB atch>b__0()
    at Couchbase.Lite.Support.ThreadSafety.DoLocked(Actio n a)
    at Couchbase.Lite.Database.InBatch(Action action)
    at System.Threading.ExecutionContext.RunFromThreadPoo lDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state)
    --- End of stack trace from previous location where exception was thrown ---
    at System.Threading.Tasks.Task.ExecuteWithThreadLocal (Task& currentTaskSlot, Thread threadPoolThread)
    at GV.EDIUS.Hub.ProjectService.UpdateProject(Project project)
    at GV.EDIUS.Hub.Controllers.ProjectController.UpdateP roject(String projectId, Project project)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMeth odExecutor.TaskOfIActionResultExecutor.Execute(IAc tionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
    at Microsoft.AspNetCore.Mvc.Infrastructure.Controller ActionInvoker.<InvokeActionMethodAsync>g__Awaited| 12_0(ControllerActionInvoker invoker, ValueTask`1 actionResultValueTask)
    at Microsoft.AspNetCore.Mvc.Infrastructure.Controller ActionInvoker.<InvokeNextActionFilterAsync>g__Awai ted|10_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.Controller ActionInvoker.Rethrow(ActionExecutedContextSealed context)
    at Microsoft.AspNetCore.Mvc.Infrastructure.Controller ActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.Controller ActionInvoker.<InvokeInnerFilterAsync>g__Awaited|1 3_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceIn voker.<InvokeNextResourceFilter>g__Awaited|24_0(Re sourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceIn voker.Rethrow(ResourceExecutedContextSealed context)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceIn voker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceIn voker.<InvokeFilterPipelineAsync>g__Awaited|19_0(R esourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceIn voker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
    at Microsoft.AspNetCore.Routing.EndpointMiddleware.<I nvoke>g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
    at Microsoft.AspNetCore.Authorization.AuthorizationMi ddleware.Invoke(HttpContext context)
    at GV.EDIUS.Hub.EHubExceptionMiddleWare.InvokeAsync(H ttpContext context)
    And
    [::1] PUT /edius-hub/asset/v1/projects/7c356c562f314d92b6e66cdd64fd9e95 409 71ms
    Context-Length: 82747
    Windows log
    Faulting application name: msedgewebview2.exe, version: 93.0.961.38, time stamp: 0x61300c53
    Faulting module name: KERNELBASE.dll, version: 10.0.19041.1566, time stamp: 0x0833f2d4
    Exception code: 0xe0000008
    Fault offset: 0x0000000000034f69
    Faulting process id: 0x5544
    Faulting application start time: 0x01d84b727eee1a06
    Faulting application path: C:\Program Files\Grass Valley\Microsoft.WebView2.FixedVersionRuntime\msed gewebview2.exe
    Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
    Report Id: 618683b8-c613-4c31-990f-5dd40c922f65
    Faulting package full name:
    Faulting package-relative application ID:
    Windows system log
    Windows successfully diagnosed a low virtual memory condition. The following programs consumed the most virtual memory: EDIUS.exe (40060) consumed 5106790400 bytes, EHApiGateway.exe (6764) consumed 1233915904 bytes, and EHRenderServiceHost.exe (6796) consumed 1227472896 bytes.
    which VST did you use?
      Acon Digital noise gate followed by Loud Max 64 on the voice track and George Young's W1 compressor for bed music on another track.
      The audio corrupts when a PNG still image comes in on the export.
        Well that's interesting.
        Having gone to Edius 9WG where I saved the project I tried going back to Edius X, and Edius 9 has seemed to fix the project export issues in Edius X.
        I do know that if a New Blue plugin crashes Edius X WG a corrupt project is the result, and it is necessary to go back to a previously auto saved project.
        I had a similar situation in another project with making proxies of UHD 50p HEVC Variable Frame Rate clips (no Quick Sync on my Xeon PC). Edius X exporter just stopped making them with the exporter refusing to export anything even a proxy of a non HEVC clip.
        I then proved that if I removed all the HEVC clips from the bin saved and closed, re-opened the project it would make proxies of other clips OK. Reintroducing the HEVC clips to the bin it would make one proxy after which the exporter went back to refusing to export anything else. So save and close, open in Edius 9 where it won't make proxies of Variable Frame Rate files anyway, made a proxy of an XAVCI clip which worked fine, save and closed.
        Re-opened in Edius X exporter now working properly.
        What I am getting at here, is I have a strong feeling that the Edius X project file is more fragile than it should be and sometimes gets itself up an alley with no return.
        I will monitor the progress of my project in Edius X and report back.
