Edius X Colorgrading with HEX/RGB codes
  • Edius X Colorgrading with HEX/RGB codes
    Hi,
    Perhaps a difficult one :-)
    I want to imitate a filmlook from a movie and i captured those colorcodes with Adobe Capture.
    Instead of using the sliders and look at the colorwheel, is there a filter/place where i can give in the HEX or RGB code?
    Thx!!!
    You can use the 3 way color corrector. Convert
    RGB to YCbCr and input the values. This can get you close.
      Hi, and is there an easy way (app) that converts RGB to YCbCr, I am not a colorexpert :-)
      Thx!
        try this page, go to the bottom and enter the RGB values, then look at all possible results
        The Best Online Color Converter. Convert colors among the most complete list of color formats: RGB, CMY, HSB, HSV, HSI, HSL, YIQ, YUV, YCbCr, CIE.
          Hi Anton, i converted the RGB code and i get this code
          • YCbCr = (81, 139, 102);
            You may need to ask Steve what he has in mind with these converted values
