Edius7 - Rusty Dinosaur Needs Help
  • Edius7 - Rusty Dinosaur Needs Help
    Howdy folks!
    Very rusty here... Used my Edius7 for the first time in a long time and when opening a project from a while back, I do some editing and at some point notice that the Project Settings are 1280x720 29.97 frame rate.
    Later, I want to pull in an animated logo setup from a different project... I open this project and the Project Settings are 1280x720 59.94 frame rate.
    I then realize that that I'm not seeing the 59.94 frame rate presets presented to me anywhere. I go to the Edius helpfile and there is a section about 'Creating New Project Presets at Initial Startup' which seems to describe choosing settings for a new preset, etc. yet I am not presented the choices described in the helpfile.
    I know I was able to create projects in both 29.97 and 59.94 frame rates, yet currently can't seem to find how to create projects in 59.94. I'm sure I'm doing something wrong. Absolutely nothing has changed on the workstation running Edius7 on Windows7.
    Thanks for any ideas!
    Sincerely,
    Mike Truly
    Truly Media
    970.349.5651
    www.trulymedia.com
    System1: Edius 7.41|Storm Mobile|Dual Xeon 3.1 (20 cores w HT OFF)|128GB RAM|Dual 512 SSDs|7TB RAID5|Dual Quadro5000s|Win7_64
    System2: EdiusNX+Exp|Edius 6.03|Procoder3|XP32|Dual Xeon 3.6|4GB RAM|U320 RAID0 15K
    Nevermind... I think I found where I can create presets down in the Settings>System Settings>Application>Project Preset> menus. I just created all the presets for the 59.94 frame rates.
    But I never had to recreate these presets before. Why did they disappear from being displayed? Oh well, they're back.
    Thanks anyway!
    Sincerely,
    Mike Truly
    Truly Media
    970.349.5651
    www.trulymedia.com
