Audio sync issue
  • Audio sync issue
    Hello everyone,
    I synced some files. Edius did a great job. Two different cameras. The mutlicam sequence appears. One of the video tracks is off like it should be. But when I change the mode from multicam to normal, still one video track is grey out and i can not see anything.
    Is there any way after syncing, to chang the multicam mode to normal so I can see and edit all the tracks?
    thank you
    I5 4690 CPU
    MOTHERBORAD GIGABYTE GA-Z97-HD3
    RAM 8GB [email protected]
    AMD RADEON HD 6800
    2X2TB WD CAVIAR BLACK (RAID 1)
    2X2TB WD CAVIAR GREEN (BACKUP)
    1 OCZ SSD 128GB
    Windows 7
    Edius 9&8 Workgroup
    Go to Mode and select compress to a single track, there will be a pop up where you choose to select output track to new track, click ok and there will be new track created with all used clips from the multi track edit above the multi track tracks.
    JoiCam´s
    And more
      Thank you very much Sir
      I5 4690 CPU
      AMD RADEON HD 6800
      1 OCZ SSD 128GB
      Windows 7
      Edius 9&8 Workgroup
