Copy window layout from Edius 9 to X
  • Copy window layout from Edius 9 to X
    Hi,
    Just upgraded from Edius 9 tot X :-)
    Is it possible to export the windows layout from 9 to X? Without changing it manually?
    Thx!!!
    You can save your old profile (but we do recommend you create a new one when upgrading like this) and some things will be saved, but you will have to set some/most windows manually the first time and then save that Layout.
      thx for the recommendation :-)
