Blackmagic Intensity Pro 4K - capture randomly stops
  • Blackmagic Intensity Pro 4K - capture randomly stops
    With both the original Blackmagic Intensity Pro and also the newer IP 4K, when capturing via Edius analogue capture, the capture starts fine but then randomly just stops early. The capture window closes and the file is produced to the point it stopped.
    Anyone else experienced this and found a workaround?
    Capturing on the same system with Media Express software from BM is fine. Captures until I manually stop. Although it flags interlace footage with the incorrect upper/ lower field first. After import to Edius I have to manually change the field order.
    Mark Stuart
    www.ms-films.co.uk
    www.ms-media.co.uk
    try the IP4k in a different slot if you have one, maybe the one it is is is shared with some other item
