Job Monitor Error
  • Job Monitor Error
    Job monitor showing error, file attached
    Can anyone solve this problem?
      Importer Quicktime error.
        Do you have any offline files in the project?
          Yes, Offline Files available in the project.
            Is this an older file? Do you have Quicktime installed on the computer?
              Can you restore them or remove the offline files if you don't need them. Make a copy of the project and do all this in the copy. Check if the export works then.
