I am told a different way to install the latest download of Edius due to some problems. In doing so I have lost Mync completely. It used to load at the same time in order but now it does not load at all . Should I go back to the original somewhere?
Mync lost
That is strange!
Do you see this folder on your computer:
C:\Program Files\Grass Valley\MyncJoiCam´s
And more -
EDIUS always removes the program icons from the task bar with an update but does not remove the program itself. What is the different way you used to install stuff? What happens if you just re-install by running the update file?EDIUS silver certified trainer.
Desktop: 2Ghz 12 core Xeon processor, 32GB RAM, nVidia 1060, BM Intensity Pro, Windows 10Comment
Thanks for both replies. Yes I ahve the Mync folder where you indicate. I switch on do nothing else then run the latest downloads version. The result is it loads correctly but then does not recognise goro files or mp4 files . It does recognise avi files Mync does not load or update. I will switch off and run the update file.E9 PRO ,Intensity Shuttle capture Nvidia 650 TI LG 3D Monitor HDMI Win 10 PRO 64 Bit.Vistitle 2.6, Robuskey. ASUS Z370 I7 8700 16 GB Hyper X black RAM 250GB 960 EVO. 2 ITB DisksComment
This means you are just doing a normal update - I only suggested that you restart then run the update in my latest video if EDIUS complained it could not do it. This sounds like something has gone wrong during the update. Have you tried uninstalling and then reinstalling?EDIUS silver certified trainer.
have just uninstalled everything then reinstalled the latest download . Result Mync although back is frozen. Edius does not read mp4 and go pro files. Started again this time using the previous Edius version everything works fine. There is a problem with this latest download whatever Grass Valley admit. I shall leave it now until the next update. Thanks all for the repliesE9 PRO ,Intensity Shuttle capture Nvidia 650 TI LG 3D Monitor HDMI Win 10 PRO 64 Bit.Vistitle 2.6, Robuskey. ASUS Z370 I7 8700 16 GB Hyper X black RAM 250GB 960 EVO. 2 ITB DisksComment
I don't tihink there is an issue with the update file as many have updated. Can you check if you antivirus software is not blocking something during installation?Comment
